sanderson_66
May 05, 2008Explorer
Our shower head does the same thing when switch is off. I thought it may be to prevent the cold blast of water when it's switched back on. I could see how this would be a problem if fresh water was limited. A couple things Jayco has improved (at least on our unit): Closet door latches, furnace heat distribution, fuel tank for gen (steel). I really like the way you can draw water from a stream into the fresh tank. Yes the pump does seem a bit loud. Our dealer said both LP tanks must be connected to run the system. Is this true? Also, the fans on the AC's seem to run at the same speed regardless of whether the speed selection on thermostat is set at hi or low. Anyone else have this occurring? Haven't used the fridge on LP yet so can't help you there Cruz. Thanks for any info. Glad to hear your trip went well Blue! Doug
About Fifth Wheel Group
