CHV_FRK
May 27, 2008Explorer
We also had an excellent extended weekend. Man I'm tired. As you can figure we also have a sureflow. I'm thinking about cutting a couple sections of tire to mount the the channels and bolt the pump to. Then I will just have the noise of the motor itself which I doubt you could hear other than right over it. Like whporwil said, you could put some foam or sounddeadoning in between.
Tonight was another round of cleaning bugs!
On topic, something that was mentioned earlier was the a/c's being ducted. Since we had a 30 amp site we were only able to run one a/c at a time. The rear unit feeds two ducts, One is short and goes to the kitchen area with 2 vents, the other goes all the way to the bedroom and feeds 4 vents. The a/c was a little noisy for Guitar Hero so we kicked on the front a/c and just closed the bed and bath vents and was able to keep the living area very cool. Another tip is to open the quick cool on the far unit if you are only running one. It helps get a little more cool air to the far end.
About Fifth Wheel Group
