whporwil
Jun 10, 2008Explorer
I can tell you a thing or to about the front remote control unit. We got our on March 4 and ours hasn't worked since March 7. First on the 08 there is a 30 amp fuse behind the battery. Look in the battery compartment, you may have to loosen the battery to see it, but it's an in line fuse. Ours was blown and when we replaced it the remote unit still didn't work but the switch mounted by the LP tanks did. Check this first. Our remote unit has been back to Alta the manufacture twice now (still no replacement)It was just sent back to the dealer last week claiming this time the on off button was bad. Our dealer is planning to install it in another camper to see if it works and that was suppose to have happened last Friday. I haven't heard a thing today so I have no clue. You should also look at the wires in the LP compartment to see if any are laying on the shaft that rotates when the landing gear motor is running. They should be attached to the ceiling but mine were rubbing on the shaft. Believe me these campers are no fun to hand crank up and down.
About Fifth Wheel Group
