M_GO_BLUE1
Jul 29, 2008Explorer
For those of you that have the generator built-in to your Designer:
You are plugged in to only 30A electrical but you need more power to run things at certain times...have you ever just flipped on the generator (without unplugging from electric) and run what you needed then turned the generator off? I'm assuming the automatic transfer switch inside will change to the geenerator power when it is turned on (since this would be producing more power thatn the 30A) and then switch back to electrical after turning off the generator...anyone every have to do this yet?
About Fifth Wheel Group
