CHV_FRK
Nov 06, 2008Explorer
Hey Dave
If you could put some pics up offsite somewhere I'm sure a few of us handy guys would appreciate it. If there's an issues I would rather fix it prior to a failure.
On the hoses, I will say this. I had the same thing happen at home. After working around the toilet I noticed and little leak on the supply valve. I thought it was a bad valve, but it ended up being a loose fitting. I know I tightened it when I installed the new toilet. I believe the will loosen up with heat/cool cycles, but also the gasket will shrink somewhat and loosen the connection. Thanks for pointing it out though. It's something we should all probably check yearly.
About Fifth Wheel Group
