cruz
Dec 05, 2008Explorer
Come-N-Go wrote:
Hey Cruz, could you take a picture of how you mounted the front leg bracket to the frame? I would likie to get an idea how you did it. THX
I could ... but dropped mine off at the dealer on Tuesday ...
It's really very straight forward following the instructions. To attach the front arms BACK to the frame ... just measure back from the landing gear, mark it, drill it, and use the self tapping bolts to attach the bracket. I bolted mine right over the corregated enclosure material ... nice and tight.
Do you have the generator installed on yours? The most difficult part of installing the front side to side arms on mine was having to lift the fuel tank for the generator enough to gain access to the top of the front Angle iron. Was easy enough to drill ... but had no access to the top portion to install the nut and washer onto the bolts.
The ONE THING I will tell you is ... make sure you have a sharp drill bit ... makes a WORLD of difference.
Hope that helps ..
CRUZ
About Fifth Wheel Group
