L_MMusic
Dec 29, 2008Explorer
We had the same trouble with the slide toppers last December. If possible, we now try to pull in the slides periodically to keep dry (even down here in Florida it's a little bit of a problem in that the slide toppers stretch under the weight of the water and don't roll up properly if they don't have a chance to dry out and firm up again.)
Ceiling seams also came down on ours a bit -- tech said he used Gorilla glue to reattach.
No squeak so far.
I was worried that we had the same shower leak trouble as Cruz. Found water outside shower returning even after wiped away -- we believe it happened because the tank was so full (next shower topped off the tank.) Once drained, no excess water. Also...no evidence of leaks underneath.
Anyone know if it's OK to have one slide out and the other in for a 24 hour period? Will it throw anything out of whack? What about having slide only open half-way?
Foot pedal on toilet sticks a bit -- doesn't close all the way unless we give it a push up. Just have to grease it a bit.
Fridge is still a bit tempermental, even with new thermister. Run-off tray in fridge has ice, but temp of fridge reads in correct range (or even a little high.)
Air conditioner leaks onto the carpet when we move if it's been running for a while. Tech said it just needed to be tightened. Wrong. Going to get another tech to look at it unless you guys know what's what.
Not bad for a full year on the road!!! Still very happy!!!
No squeak so far.
About Fifth Wheel Group
