sanderson_66
Jul 28, 2009Explorer
M GO BLUE wrote:Any electronics store should carry a switchable splitter. It has one or more inputs and one or more outputs with a selector switch built in. This eliminates the need to disconnect and reconnect the cables...just slide the selector switch to get desired input to desired TV. Sounds like you just may need a splitter with more outputs.loydt wrote:
Blue, for tv just slide the panel back as if you were accessing your central vac. Look for the grey coax cable there. If you have the ext entertainment center you will see where they installed a splitter for it. Just use that splitter for a tv hook up but remember if you want to feed a seperate satt receiver there you cannot use a splitter. FYI, that coax continues on to feed your bedroom tv so if you disconnect it to watch tv outside you cannot watch in the bedroom.
The plan is to disconnect the cable at the splitter where it goes to the bedroom and then screw-in the cable from the basement TV when we want to do that...when finished we'll switch the cables back
About Fifth Wheel Group
