CHV_FRK
Aug 11, 2009Explorer
Yes. We just had ours replaced. We would get all sorts of weird issues. Even hot water in the toilet... Kinda crazy seeing it "steaming" when your done with it! "I swear, it wasn't THAT bad!"
That's 1 mixings valves so far for us. I'm not sure if it's the water or maybe draining and that's aiding in corrosion. I've seen that they maybe serviceable. I'm sure that will be attempted on the next go around since our warranty is up in 3 months. I was not allowed to work on it myself prior. *edit* Location is at the water heater on the upper output stub. Should be where you bypass ties in cold supply and hot. *edit*
We still have to take our unit in for some major water collection under the nose. We think it's the lower trim on the sides that breaks the seal everytime you transfer weight to the pin..... at least I hope that's what it is.
Hoping to go somewhere this comming weekend.!
About Fifth Wheel Group
