- petekerwienExplorerWell today I filled everything and let the grays drain for long time. I gained one red dot. SO sounds like I need to put chems. in there. I am sure tomorrow's ride on the Alaskan Hwy will help shake them up. I might even aim for one of those bumps!
- CHV_FRKExplorerYou probably have stuff built up in the grey water tank.
I would probably fill and drain the tank once, then add one of the enviromentally friendly chems out there and fill you tank and let it sit for up to a week to allow the chem to help loosen whats there. Drain it of that, then fill and drain one more time to rinse. Water is the best solution.
What I do is after I drain and when we get home I like to add almost a 1/3 tank of just water to keep what might be there moist. On the black tank I do use the campchem treatment. I do that all camping season. I don't do it in the winter, I just make sure the tanks are flushed well after each use. - petekerwienExplorerMy gray water tanks (one of them especially) show 1/2 to 3/4's full. I drain them until nothing is left (I allow a lot of time because of the difference of pipe diameter of these tanks.) and the indicators shows 1/2. Black tanks, battery, fresh all read correctly. My next step is to fill the grays intentionally until they are full, then drain them to see if there is something in the tanks to dislodge...or it's the indicator? Any suggestions?
- petekerwienExplorerAh that's it. Thanks
- CHV_FRKExplorerConvection oven. Microwave and Convection.
Some units that have these do not have ovens and have drawers instead. - petekerwienExplorerSomeone please tell me what a "half-time oven" is? Thanks.
- whporwilExplorerI just saw that we had 4.84 inches of rain when my camper leaked.
- whporwilExplorerDana,I vented my Convection oven to the outside after seeing your pictures last year. And I only took off the second belly skin to expose the black tank. Thank again for these pictures.
AL - M_GO_BLUE1ExplorerIf I remember correctly behind the flapper on mine is styrofoam stuffed in there but I'll double check next time I go to storage...I hate not having this thing parked next to our house!
- CHV_FRKExplorerHave you other guys with half times' looked behind your vents to see if you have a hole? Mine didn't, just the plastic part on the outside.
About Fifth Wheel Group
19,031 PostsLatest Activity: Apr 14, 2024
