- brianreed0715ExplorerJust wanted to say thanks for all the usefull info regarding the the 35RLTS, it has been a great RV but we are selling ours. We ran accross a great deal on a Fleetwood Revolution Class A so we decided that would be better for us and our situation. If you guys know anyone interested in a loaded 2008 Designer 35RLTS, shoot me a message. Other than that you guys have been great. Thanks again.
- HoopsExplorerDo you want to search in side this thread only or 5th wheel forums? I don't think you can just search this thread. Do an advanced search pick your topic and forum and go from there. Any topic on tires that was posted in the Designer 35RLTS will show up if you use the 5th wheel as your forum.
- CHV_FRKExplorerFirst get a weigh in and determine what the weight is on each tire. Pull just the trailer on with each axle on a different plate. The. Pull back on with each axle on a different plate but one side off the scale. With a little math you can figure out the individual weights. That eliminates loading as an issue. Next would be allignment. You can go to a trailer/semi service center as they are the only ones equipped to do this correctly. I would also have them add greasable shackles in lieu of the stock ones that will fail! No sense in paying for an alignment twice. Tires, i would stick with be goodyears. In this area you're still gettn what you pay for. Good luck
- brianreed0715ExplorerI'm sure this topic has been addressed already but can not figure out how to search within this forum only. It's about time I replace the tires on my 35RLTS and was needing some feedback on which one to buy. Loosing quite a bit of thread on the driver side front tire. The inside thread is nearly gone (just smooth) I may need some help as to why this one looks so bad compared to the other ones. Thanks in advance for the help.
- mudmakerExplorer
whporwil wrote:
Hi everyone. Get this, our counter top has cracked from the right rear corner of the stove back to the wall. Called our dealer to see if it can be fixed and was told it should be replaced. Jayco wants $2550.00 plus $100.00 for crating and $250.00 for shipping. I guess it's not that noticeable.
I could drive to the factory for less than 350.00.
The price of the top seems out of line also. Get ahold of a local countertop dealer and have them measure for one. Bet it's less than that. - CHV_FRKExplorerProblem solved... I don't have one.
Melissa, you better get in there. Lord knows you don't need anything else to go wrong! - northmeck0255ExplorerOur transfer switch failed and melted last week. It was replaced by Jayco under warranty.
- RedGExplorerThanks for the heads up on the recall. I'll be watching for the notice from Jayco. In my trouble free 35RLTS in Aransas Pass TX at the moment.
Sorry for the double post. The WiFi is really bad in this RV park. - RedGExplorerThanks for the heads up on the recall. I'll be watching for the notice from Jayco. In my trouble free 35RLTS in Aransas Pass TX at the moment.
- whporwilExplorerHi everyone. Get this, our counter top has cracked from the right rear corner of the stove back to the wall. Called our dealer to see if it can be fixed and was told it should be replaced. Jayco wants $2550.00 plus $100.00 for crating and $250.00 for shipping. I guess it's not that noticeable.
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 24, 2026
