- scootskExplorer IIICould anyone tell me what the outside storage A/V RCA jacks are for? It seems to me that it would be for hooking the outside Tv to the interior entertainment center DVD player. But it says video in, which leads me to believe that it is to hook up an external device such as a DVD or gaming system. Why do this if they could be hooked up directly to the TV?
- M_GO_BLUE1Explorer
loydt wrote:
you may just have a loose connection in the actual outlet. Id try to get that apart and take a look there first
That is my next step...as you know that outlet is accessed outside in the fridge access door...undid the screws holding it to the wal and the outlet did not move...probably all that brown insulation they have around the plug that is preventing it from moving and will have to be scraped away... - loydtExploreryou may just have a loose connection in the actual outlet. Id try to get that apart and take a look there first
loydt wrote:
hmmmmm, checked all the breakers??????
Checked the breaker for the fridge (and all other breakers) and none had tripped...
Is it possible the breaker for the fridge blew but did not trip itself? If so how easy is it to replace a breaker? - CHV_FRKExplorerI'm not sure if the outlets run the same on our unit, but the RLSA power runs to a junction box under what would be your street side bathroom floor in the service area. It then proceeds back to the fridge. For Electric this should only run on 120VAC. I would e-mail or call Jayco and have them send you the 120V diagram for your unit to help you track your issue down.
- Rough2000Explorer
2007dura wrote:
Having trouble with front cap dulling also. Actually starting to get some yellowing in some places, noticed when I waxed a few weeks ago. Tried different cleaners and cleaner waxes to no avail, looking at going with something stronger now.
I have used "Rejex" on my Designer... it is now two years old and it looks as good as the day I bought it. It's a little harder to put on and off than some others but I believe it is well worth it. - loydtExplorerhmmmmm, checked all the breakers??????
- M_GO_BLUE1ExplorerOk guys had the refrigerator stop working on electric this weekend...
Through all the testing I did I found no power going to the electrical outlet where the refrigerator plugs into (located inside the outside access door for the refrigerator)...
Anyone know if this is connected to a fuse or maybe a GFI outlet? (only GFI's I know of are the bathroom and kitchen and maybe outside entertainment system plug) Any help? - TravlingmanExplorer III have been using Protectall folowed by 303. Use Maquires couple times a year too. Tried the Maquires cleaner wax along with Gel Gloss, neither helped. Going to a marine store to see what they have. Saw some Protectall oxidation remover, thinking about giving it a try.
- loydtExplorerHmm, mine has never done that? As for the front cap, I need something along the lines of a compound, etc. A medium duty restore type wax. I have a guy who is good with a buffer but I'd like to provide the wax that I know is SAFE for gel coat fiberglass.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
