- CHV_FRKExplorerIt wasn't a quote from a post, I typed it up from the brochure.
- cruzExplorerCHV_FRK ... so I'm not sure why it got edited out of my post.
Yea ... it appears our administrator/moderator doesn't like it when we "quote" other posts in our responses ... so he deletes them !! :-( - CHV_FRKExplorerM GO BLUE,
It was a quote of what the Polar Barrier stands for. It's an option on the RLTS/RLSA models so I'm not sure why it got edited out of my post. - M_GO_BLUE1ExplorerCruz,
Never noticed that it got hot in the pantry next to the fridge but I'll keep an eye on it...
Meet in New Mexico? Heck we'd have to use all our vacation just to make the drive there! :) - L_MMusicExplorerCruz -- Same window. Will either be getting it repaired up in buffalo next month or not.
- cruzExplorerHEY !!!
I see where "THE RALLY" is in Albuquerque, NM next April !! :C
Think this is our opportunity to meet fellow "Designer" Owners !?!?!
(CHVFRK - Notice I didn't say 35RLTS owners!) :B
CRUZ - cruzExplorerRE: Gas Tank ... I have two 5 gallon rectangular plastic gas "cans" that I can get all but about a 1/2 to 3/4 gallon out of if I twist the fill nozzel to the side. I dump them both into the tank, then transfer the remaining from one into the other and dump it again. End up with about 9 1/2 gallons out of 10 in the tank ... not too bad.
Fridge - Good Pics Ed ... I have a couple of fans and a small illuminated switch I'm going to mount inside so I can turn on/off. This should help with reducing the heat build up in the pantry too !Thanks;
M GO Blu - when you ran the fridge for those 9 days on LP, did your pantry get really hot inside? Ours did after a day or two.!?!
CRUZ - cruzExplorerL&MMusic is this the one that broke a few weeks ago ... or did it break again ??
CRUZ - whporwilExplorerHi everyone
Discovered something this morning you all should know about. First I'm an RLSA owner and I have been having problems with my front remote control landing gear. Today I removed the LP tanks to fill them an discovered two wires that come from the back of the compartment to the front of it laying on the shaft that goes from the electric motor to the other side of the trailer. Since this shaft turns any time you raise or lower your front gear it needs to be moved out of the way. - M_GO_BLUE1ExplorerOk now why are some of you installing fridge fans???
We had ours on for 9 days straight on LP and never had a problem....
As for CHV...what does that article refer to?
About Fifth Wheel Group
