- M_GO_BLUE1ExplorerSounds like something is leaking somewhere...water pump is losing its built-up pressure and therefore turning on
- L_MMusicExplorerHas anyone noticed the water pump turning on for a brief moment when no one's using the water? Is this normal or do we have a leak somewhere?
- loydtExplorerI do have the Mor Ryde so I guess we will see. He can just call me if they dont fit and I will run and get some. I want them back on there.
- BCCDALExplorerYes he was probably talking about the spacer kit for the non Mor-Ride suspension.
- CHV_FRKExplorerMy dealer said something about shock extensions. Was he thinking of the non-Morryde?
- cruzExplorerIf you DO have the Mor Ryde Suspension, the shocks will NOT be long enough ... this comes from Mor Ryde directly !!
When my dealer did the lift, they are the ones that informed me the shocks weren't long enough AFTER they had already lifted it and tried to re-install the shocks !!
CRUZ - BCCDALExplorerLoydt;
If you don't have mor-ride system the shocks will fit. You need a spacer kit from Jayco for $5.00, order from your dealer. The kit has 8 spacers, 2 for each shock. The Jayco part number is 0088382.
O - eaherrmannExplorerWe're Back :) Wow did we have fun. This trailer is the bomb for dry camping. Everything worked perfectly! We did find the the water pump was a tad bit loud, I'll figure out a new suspension mount that will fix that problem. Genny worked perfectly and we used all of 10 gal of gas the whole 4 day weekend. Here's a picture. Happy Camping ;)
- loydtExplorerSomeone on here said that when you have the suspension lifted the shocks will no longer fit? My dealer says this is not true.
- TravlingmanExplorer IIHad my suspension lifted at that time too.
About Fifth Wheel Group
