- AUWingExplorer
CHV_FRK wrote:
Our trailer got to enjoy 170MPH winds.... :) .
WOW - good to hear it's all OK. That would be a lot to deal with, especially the '49 (says someone with a '37 chev 3/4 ton) - AUWingExplorer
eaherrmann wrote:
Hey All,
OK..we finally de-winterized and lo and behold the bypass valve on the hot water tank has siezed. Atco calls the valve a mixing valve and it olny costs $199 plus shipping, oh joy. Has anyone else had a problem with theirs? I went ahead and "manufactured" one from lowes parts but now the meaning of HOT water is OMG :E We're talking jumping out of the shower hot.
OH Yea, hi all! :) Welcome to Spring!!!!
Yep same issue and same phone discussion underway. I'm told you can remove the cap on the valve and turn the stem to clear anything that might be upsetting the flow. I plan on trying before opening the wallet that wide for something that should never fail under reasonable care. - L_MMusicExplorerHoly cow, Dana! Didn't know you were so close to there. Glad you're OK -- and at least most of it is better off than it could be. See you on FB.
- whporwilExplorerI was thinking about you and hoped you didn't live by the airport. Thanks for letting us know your ok. If you ever make it to South Party Island make sure you bring the Dragon Wagon, there are lots of cool cars and trucks down there.
- CHV_FRKExplorerOur trailer got to enjoy 170MPH winds.... :) an EF4 hit our storage lot. Or fifth wheel and my 48' Enclosed car trailer with 95 Roadmaster Wagon and 49 Chevy P/U. Had a bit of luck though. The 5ver just got the back window smashed and some roof membrance damage. Luckily the window tint held it together so no water damage as of right now. The car hauler got another enclosed trailer thrown against the side. A few holes and the rear ramp doesn't seal when it closes anymore. it's 15K, only 8ft tall, and it got moved 10 ft. For those that saw the blurb on the national news we have it by the St. Louis International airport.
Heading out after work to board the window so we can camp this weekend. I'm no quitter!!!
Other trailers and buildings were not so lucky. Several TT's picked up and thrown. Bridgeton, MO 4/22/11 for those that want to look it up. - L_MMusicExplorerNo problems here yet with the hot water heater except the pressure valve needing replacement last week.
Just removed the damaged rear stabilizing jacks. Driver's side got bent while negotiating a hill/turn and apparently occasionally bottoming out has worn away areas. $1,000 to replace. Removed and are now using a pair of 6,000 lb jacks for $20.
Drawer under couch broke (probably too much weight (limit 50lbs.) Since I've been covering the couch with a nice soft flannel sheet anyway (upholstery is fraying a bit and has always been rough/yucky feeling), we simply removed all of drawer except sliding hardware. Bought a plastic tub to hold contents and left 1/2 open as hiding place for dog. Sheet also reduced dog smell as is easily washed! 1/2 empty area works well on travel days for dog toys and printer.
The metal we added to the wood under the bed where it rests when slide is in has been working great. Just needs a little guidance by hand to get into the slot.
Got a Bissell upright vac to replace the central vac that died. What a diffrence!
DVD player died -- Larry found one that will fit and work with surround sound system -- Yamaha YMC-500BL.
Currently "enjoying" 50 - 60 MPH winds in Albuquereque!
Happy Trails! - eaherrmannExplorerHey All,
OH Yea, hi all! :) Welcome to Spring!!!! - double_clutchExplorerHappy New Year Everyone
Has anyone installed the Traveler Antenna on their Designer and if so have they found a sat cable buried under the rubber roof, maybe around the antenna
thanks
Don - sirdrakejrExplorerAnd to all you Jayco owners, have a great year and save travels.
Frank - petekerwienExplorerThanks Ed I'll chime in and wish you all a Happy New Year too! Have safe miles.
About Fifth Wheel Group
19,033 PostsLatest Activity: Mar 04, 2026
