45Ricochet wrote:
RC is correct at 2360 and the hitch off loading the front axle by 180 lbs. My front weight doesn't change much when hitched up but front passengers weight is almost totally front axle weight.
9680 would be your hitched up total weight on your D/A 2500. Not sure of your GVWR but your most likely a bit over that rating. I also use GVWR but like Jim said many run with RAWR which generally is the rear tire rating x2. That era of 2500 is a little over 6k lbs.
Believe his GVW on the Chevy 2500 is 9200#.......
