snowpeke wrote:
My Jayco has E Z lube bearings. The Dexter has a you tube video and shows that you pump grease in until the new grease comes out. I called a Jayco dealer and he says not to do it that way. Says that grease gets in to the brake drums. Witch way do I go?
It's rare but the dealer actually told you something truthful and helpful.
Dexter e z lube does work if you baby it. Going really slow and spinning the wheel a lot to protect that rear seal otherwise greased brakes.
Pulling the hubs and knocking out the bearings isn't so bad, and it gives you a chance to inspect the bearings and spindles.
