Memphisdoug
Jul 29, 2015Explorer
The problem is that 50 amp to 30 amp adapter you used. Any 30 amp plug going to your camper can only have 120 volts input to it - 3 wires, a ground, a neutral and a power. If you didn't have that 50 amp to 30 amp adapter on the trailer then you would have been fine with the 4 wires coming from your generator - a ground, a neutral and 2 power wires. If you want to use that generator with your trailer get rid of the adapter
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
