Acei wrote:
Thanks for more information on the LP generators, guys.
Looks like the LP gens are the best option for me. I especially like that fact that LP gens don't require much maintenance when used occasionally. I'm going for 900+w solar setup with 900+Ah 6-battery setup so hopefully, I won't be burning through propane at a crazy pace.
Don't forget that you're looking at straight generators. They either run at full RPM all the time, or idle. You should also consider the inverter-style generators. They only run as fast as the load demands, which is why they have such great fuel economy. As far as I know (and I haven't looked in a while), Onan only makes pure generators and no inverters. Hell, you can buy a 7500w generator at Costco for < $1,000, last I looked. Loud and fairly uneconomical, but they work and will charge your batteries and run your AC, when needed. The difference in price will buy you a =lot= of fuel =and= another generator if this one craps out, then still =more= fuel. :-)
Lyle
