MitchF150
Oct 09, 2016Nomad
Just get a 50a to 30a adapter. Plug into the 50a on the pedestal, flip the switch and all you'll get is 30a power into your rig..
If you exceed 30a in the rig, your rigs breaker will blow first. The same as if you plugged into a 30a pedestal.
Plug into the 20a and you'll still be fine.. You'll just blow the breaker on the pedestal if you go over 20a in your rig, so you won't be able to take advantage of all 30a in your rig.. Easy, huh... ;)
Good luck!
Mitch
Good luck!
Mitch
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
