filthy_beast
Oct 11, 2016Explorer
No disrespect intended, but if you do not know whether 117 volts is good you should probably not be doing electrical troubleshooting.
The Powermax PM3-55 is a 55 amp converter, the Magnatech SF-40 is probably a 40 amp converter. The wiring size for these two converters is different and installing a 55 amp converter into wiring that is designed for 40 amps can be a safety issue.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
