lincster
May 20, 2013Explorer
As said, DRW is rated higher in GVWR and sometimes GCWR, both good when towing heavy.
If you have a rear tire blow out with 4000lbs of pin weight, I would want 1 extra tire to help control the load until I got pulled over.
More stable in the sway department with high winds and when you get passed by a semi doing 75mph.
About Fifth Wheel Group
