mcateefam's avatar
mcateefam
Difference in pulling
Hello community,
We are looking at stepping up from a travel trailer to a fifth wheel. We have looked at many different bunkhouse style trailers and are looking at either a Cougar 336bhs which is ~38' or a Montana 340 with is ~41'.
I have a 2013 RAM 3500 with 6.7L Diesel and AISIN transmission.
My question is will I notice a difference in drivability between the two? Turning, Start, Stop, Highway?
Thank you for your support!
  • The biggest differences I noticed #1. backing up....reacts slower so you have to turn sooner, #2. being passed by semi's doesn't get the "suck in/push out" feel...much more stable.
  • At first it will feel like you are towing a house behind you. Quickly you will become just as comfortable towing a 5th wheel as you are with a TT
  • Sorry about the lack of clarity.
    I am asking is there a difference in towing between the two 5er's.
  • Towing difference between your two choices? No, not really. You will still be shut out of some camp sites due to length wirh either one.
  • Are you asking if there will be a difference between the tt and 5er? Or between the two 5er's?
    You will definitely notice a difference between the tt and 5er.
    As far as the 38'or 41'er.. not much, except on tighter turns.
  • The 5th wheel will be more stable towing in cross winds. And a 5th wheel turns more inside the turn radius of the truck, so you have to take somewhat wider turns to avoid hitting curbs or dropping off in ditches, just like a semi on a smaller scale. But otherwise, no difference in starting and stopping and general towing.
  • rhagfo's avatar
    rhagfo
    Explorer III
    Yes, you should notice an improvement in towing, braking and turning are about the same, a 5er does track a little more inside on a turn than a TT.
    You will find a 5th wheel is taller, so you just need toi be aware of that.
