Only_True_Mosno's avatar
Oct 28, 2017
Direct TV Won’t Work on my 2018 Montana?
So something is not working for me. I am getting a Signal 775 trouble communicating with dish. I have 3 connections in the outside command center. 1 for cable..2 different ones that both say satellite.
First question is which satellite connection to use? Bottom one or the one in the middle? ( I have tried all 3 with no results)
Second I am only trying to get it to work in living room. The wall socket says cable for one connection and satellite for the second. ( I have tried both with no results)
So I ran the cable directly from dish into a window and connected to reciever. Works fine.
So I have a wiring problem somewhere and have no idea what to do next???
I am experienced dealing with satellites tailgating and RVing and know it is something in the new RV. There is no green light button in the living room outlet and I turned the green light off in the bedroom with no results. Thoughts?
  • You need to do a continuity test on each cable connection to determine which cable goes to which TV and to determine if the cables are actually connected properly at each connection plate.
    Not a difficult task and you need a multi meter to do so.
  • We had the exact same problem with our Montana a 2017 when we hooked up directly to the TV it worked fine when I went through the RV wiring it wouldn't work
  • Well I wonder if he got a meter and homed out the connections or got a cable tester to verify which goes where?
    With the proper test equipment it would easy to find what goes where
    Also.. I’ve been using GTV for many years and have zero regrets. And in this case the provider service has absolutely nothing to do with the guys isues..
  • I've had DTV with the last two 5er's, and always had to run directly to the DTV box. I don't know what satellite they wired for but it did not work .
  • GHop wrote:
    Don't use Direct TV you will regret it.
    Have had DIRECTV for close to 25 yrs, never had an issue that wasn’t easily fixed. Full timing got over a year with auto satellite on roof and a Genie in the living room and slave in bedroom. Never had a problem. Have never regretted it and enjoy it everyday.. as stated zero issues.. works every time.
    Jim
  • We had the same issue. Go to the rear tv and turn off the antenna booster. Problem solved.
