mudmaker wrote:
Glad I read these posts. I too have been having a hard time getting locked up sat signal with dish. Seems to be getting super finicky. I was going to to spider hunting, figuring there was probably one building webs inside the dome and somehow fouling it up.but, if parts can move around a little making it work harder to get the job done then there's more reason to do some investigating.Otherwise there isn't really any turning to a Winegard dome dish, is there?
The satellite inside the dome not only rotates approx. 360 degrees, but it also steps up and/or down, all this to lock onto the satellite signal..so yes, there is more movement inside the dome than what you might think...
Before I went with the Trav'ler HD satellite, I had a dome and on occasion, I would take the dome off (easily done) and inspect the unit to make sure all was well...I had to replace a limit switch one time when it wouldn't lock onto sat. sig... I found this myself...got part through Winegard under warranty...Alway's found them pretty good to deal with.
