fpresto
Mar 10, 2014Explorer
If, as you said, the pump is getting the proper voltage then the controller is doing it's job and the problem must be elsewhere. Early Ford controllers had a problem in that a slow speed, 15 MPH or less, the controller did not send enough power to activate the pump. Your 2012 should not have that problem.
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 24, 2026
