marspec wrote:
Atom Ant wrote:
The module is also required for the Ford brake controller, otherwise it things the trailer is not connected and alarms.
Late model Fords do not require a separate module but I'm not sure when that started. Initial setup of the installed controller asks if RV brakes are electric or hydraulic.
Ya we towed our Redwood with disk brakes home with a 2006 Ford, and it needed the module. The 2006 did not have the select option for disk/electric. Not even real sure if this 2008 does.
