psford wrote:
Not sure about the 200 mile range, I have gotten local channels as far away as Phoenix ,Az , 700 miles from home, finally lost the locals when we got to Tombstone area 850 miles from home.
It is not really a range thing.
You get local channels from a 'spot beam' transmitted from the satellite. That beam footprint is usually about 400-500 miles in a near circular pattern. Its kind of like shining a flashlight on a big beach ball. You have to be in the lighted area to receive those 'local channels'.
There is not a separate spot beam for every location. People living 150 miles from me are in the same spot beam coverage as I am.
If your home zip code is in the center of that beam - then 200-250 miles away, you normally lose local channels. If your home is near the edges of the coverage - you might lose locals 80 miles from home in one direction and 400 miles from home in the opposite direction.
Spot beams coverages out in the unpopulated areas of the nation - mostly out west - are a bit larger to lower the cost for the satellite coverage. So you could easily get more range.
psford wrote:
The one thing I do know is that my friend that I camp with in Montana every summer has a much more difficult time getting Dish reception then I do with Direct for whatever reasons. I point mine somewhat south easterly ,and I got a signal.
As mentioned above - it is a factor of satellite position. The Direct satellites are apparently higher above the horizon than the Dish satellites. The closer to the horizon, the easier it is to have a signal blocked by trees, mountains, the next rig over in the campground, etc.
I didn't know that - but will be something to consider if I decide to spend a lot of time far north.
A question for Direct TV users - does anyone full-time with no Direct TV home contract/ setup?
