- G-DadExplorer
nremtp143 wrote:
G-Dad wrote:
I have the same truck with about 3K pin weight from my fiver. Good roads all OK. Bad roads, potholes and hard bridge expansion joints not so good. Thinking seriously about adding some sort of rear suspension assist.
Part of the reason why my last tow SDs have had airbags on them. Plus, it took away the "launch shudder" that some of them have. Another plus is that I put in an onboard air system with pneumatic controls so I can change the pressures in the bags when the road conditions change.
I also have a VIAIR compressor/tank unit in my truck. What control system did you use to interface the air bags to your air system? - JIMNLINExplorer III
old guy wrote:
hook up and see how level the truck stands. let that be your answer
Good post.
Lots of guessing here. Load 'er all up and make a run down the road.....then decide if any suspension help is needed. - Garry_GayleExplorerI carry 4300# pin weight on a 15 F350 DRW, I can get by without air bags but 40psi in the bags improves the ride.
- Cummins12V98Explorer III
FishOnOne wrote:
Cummins12V98 wrote:
If you needed them on your 05 you will need them on your 16. Same rear suspension. 2017 is when they stepped up.
Wrong....
OK, just cuz u r DaFish does not mean you can get away with "WRONG" Cummins12V98 wrote:
Wrong....- Me_AgainExplorer III
What he said^^^^^! - Cummins12V98Explorer III
azdryheat wrote:
My Voltage has 3500# on the pin and I haven't found the need for bags.
That is not a lot of pin. I am sure you would not need bags even at 4,500#. The last generation of Fords seemed to need bags more than GM or RAM. - LwiddisExplorer III disagree! A brand new truck, a 350, and OP thinks air bags may be needed? Why isn’t the same as buying a Ram 1500 and trying to tow a “way too big” TT? OP bought an inadequate truck.
- nremtp143Explorer
Part of the reason why my last tow SDs have had airbags on them. Plus, it took away the "launch shudder" that some of them have. Another plus is that I put in an onboard air system with pneumatic controls so I can change the pressures in the bags when the road conditions change. - azdryheatExplorerMy Voltage has 3500# on the pin and I haven't found the need for bags.
About Fifth Wheel Group
19,031 PostsLatest Activity: Dec 15, 2025
