davisenvy's avatar
davisenvy
Do I need airbags?
I just purchased my first FW last week. When hooking up, the rear of my truck squats around 4-5 inches. I have towed the FW on a short camping trip and the FW towed very nice, but the rear does sag quite a bit compared to my last TT set up. I bought some Timbrens and installed them earlier on this week. They absolutely ruined the way my truck drove unloaded so I didn't even try to tow with them.
How many on here are running air bags? From the pics in the "Your Rig" section everyone seems to be pretty level in their towing. Do they ride rough when towing?
  • I would add the air bags --- they are good to have. See my signature line. Our trailer has a pin weight of 2975 lbs. I have the ride rite air bags and only keep 20 lbs of air in them. They keep the truck level and mainly keeps it from bottoming out when we hit a hard bump in the road.
    Enjoy the road. We do.
    bigdon68
  • Maybe the truck doesn't sag that much, but it does sag. I have the front leveled a little bit so that makes it look a little worse than it is. There is still a 1.25 in rake.
    The Timbrens were installed without the spacer disc provided. Without the disc installed there was a 1.5 in space for suspension travel. When I would hit a bump or a bridge expansion it would feel like the truck was bottoming out on its frame.
    The truck is a 2006 with 120k mi. Could my leaf springs be worn out?
  • Howdid the timbrens ruin your ride when they are just a overload stop not in use unless towing?:h
  • rhagfo's avatar
    rhagfo
    Explorer III
    Well bags may be in order, but that 5er should not squat your TV 4" to 5"! You must have ordered your TV with the Max Smooth Ride package rather than a tow or payload package. :S
    Weights
    Unloaded Vehicle Weight 8,300
    Dry Hitch Weight 1,515
    Gross Vehicle Weight Rating (lbs) 9,950
    Cargo Carrying Capacity 1,650
    Even at GVWR, the pin should not exceed between 2,000# and 2,200#. Really should not cause that much squat.
  • I do not need any suspension help. Mine only squats 1-1 1/2 inches, depending how heavy I am loaded. If you are dropping 4-5 inches, yes, I would add bags. If you ever towed at night, you would be blinding oncoming traffic.
    Jerry
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 24, 2026
