- PuddlesExplorer
gkerlin wrote:
TubaPete wrote:
"Do you jack up your 5th wheel with the landing gear down?" Yes. I know one side gets a lot more weight than the other, but these things do have a margin of error (safety factor) built in.
Just curious... what engineering documents and/or technical specifications for the OP's specific landing gear did you consult before you advised him that his landing gear had a built in safety factor?
If none - then where did you get that knowledge to pass along as fact, that he was safe jacking the trailer while supported on his specific make of landing gear?
I mean come on... We constantly hear about broken frames, blown tires, busted springs and axles etc. Seems to me that safety margin went the way of the dinosaurs.
Responsible advice is to play it safe and hook up.
X2 - Cummins12V98Explorer IIITrailerAid Plus, so simple and so safe. I guess no one wants to think outside the box!
- gkerlinExplorer
Responsible advice is to play it safe and hook up. - redfire2002ExplorerIf you put the jack under the axle and jack up just enough to pull the tire, your putting the weight thats normaly on that tire to the jack. All your doing is compressing the springs alittle, its not like your jacking it to pull both tires off the same side at the same time. No need to hook up to TV and this way is safe
- TubaPeteExplorer"Do you jack up your 5th wheel with the landing gear down?" Yes. I know one side gets a lot more weight than the other, but these things do have a margin of error (safety factor) built in.
- wandering1Explorer
GMT830 wrote:
Jacking up one axle end at a time enough to get the wheel off isn't going to twist the frame enough to significantly unload the landing gear
x2 - ol_Bombero-JCExplorer
GMT830 wrote:
Cinder blocks are notoriously week when standing alone. They should not be used to support a vehicle of any kind.
Amen!
Cinder blocks = "Design for Disaster".!!.:S..:(
Back to the OP's question.....
Done it both ways with no ill effects.
However - "we" aren't on "the hook" for repairs if the OP tweaks something!
Best CYA advice (for him & "us") is hitch up, and jack under the frame, with landing gear retracted)..:C
~ - GMT830ExplorerCinder blocks are notoriously weak when standing alone. They should not be used to support a vehicle of any kind.
I had to correct my spelling of weak. Siri has been having trouble with it all week lol - GreentreenaExplorerI did it once and the cinder block the jack was on broke into pieces, since then I've hooked the truck up prior to jacking the trailer. There was no damage but I don't want to take any chances.
- hotrod4x5ExplorerI did it once, jacked up each side (one side at a time), to get new tires. Left it sit that way for at least an hour per side while I took the wheels to the store. Didn't seem to do any damage that I could detect.
About Fifth Wheel Group
19,008 PostsLatest Activity: Mar 07, 2025
