ajriding
Dec 20, 2018Explorer II
Tie-Downs
I have two questions.
1. I have the tie-downs that drop into the square holes on top of the bed rail (Ram 2nd gen).
I have never used these. How strong are they? My camper is 1800lbs dry.
I plan to use these in the front.
2. For the rear I want to make something that attaches to the receiver hitch extension. A long bar welded to the extension, right at the receiver, that spans out to hold the tie-down chains.
Who has made or used one?
What steel tube do I need? I was thinking a 2 inch square, but could would a round steel pipe from the HD plumbing dept be enough? I will weld it all up.
Also, I have a gooseneck hitch, so there is a solid anchor point in the center of the bed. Has anyone used this a a 5th tie-down point? It would not do much for topple, but would keep it from sliding.
I'm back at the truck camper game after two years of trailers. I had a slide-in pop-up so did not need much to keep that in place. Now have a full height unit, 9.5 feet long. It does not have any cabinets high, really nothing but the shower door and curtains within the top 20 inches, so cant be as top heavy as most. It does have roof AC.
I will be towing a cargo trailer also, light, single axle.
I am buying the camper tomorrow Dec21.
