- Aquaholic502ExplorerHas anyone put LED's in the existing fixtures yet? I would like to put some of the Rigid industries LED's but they are on a flat plate and the inside of the fixture is rounded so not sure how well they would mount.
- adams92207Explorer
Macs Dad wrote:
Nice filter. I was going to just add a cheap high flow in line clear plastic type between the tank and pump and another one at the fuel line that feeds the gen from the tank as it looks like they are seperate feeds. The Onan 4000 manual shows the gen having a fuel filter on the left side of the gen. Good luck getting to it to change it while it'd in the trailer.
Info from cummins site also says it has filter.
http://www.cumminsonan.com/rv/products/gasoline/compare?gensetId=130&detail=true - adams92207Explorer
my996duc1 wrote:
danojeno wrote:
Mine has a high pitched buzz for the first few minutes of charge, then it disappears...does your noise disappear after a while?
Mine seems to be buzzing all the time now (when nothing 12v is on).
Yesterday it quit for abit but today it is non-stop.
I talked to the guys at Attitude/Eclipse to see if they had heard of this problem. They thought it might be a relay. I will try to take mine over to them next week and see if they can find the problem.
_
Good info so far guys! I am in email correspondence with them and mine is in pre delivery inspection as of today at the factory. it is getting inspected tomorrow so im hoping to possibly get it this weekend. I will be looking at all these things and asking lots of questions. - Macs_DadExplorerNice filter. I was going to just add a cheap high flow in line clear plastic type between the tank and pump and another one at the fuel line that feeds the gen from the tank as it looks like they are seperate feeds. The Onan 4000 manual shows the gen having a fuel filter on the left side of the gen. Good luck getting to it to change it while it'd in the trailer.
- BakersfieldExplorerNice job.
- my996duc1Explorer
_ - RacormanExplorerI have not checked, but I think the generator has it's own inline filter. I really should check on that. I do know that the 4000 generator does not have an oil filter and the oil needs to be changed after the first 10 hours of service.
Here is the fuel filter I installed for the fuel station....
Racorman wrote:
By the way...
Before you use your fuel station to pump gas into your toys, make sure you run about 1/2 gallon into a glass jar. I found lots of crud came out of the virgin fuel pump the first time I used it. I quickly installed a fuel filter before I used mine again.
So how did you keep the crud out of your generator? I did not really need the fuel station (we carry fuel cans) but I have to order it to run the generator. I have not checked, but I assume the generator has an in-line fuel filter? - danojenoExplorerMine has a high pitched buzz for the first few minutes of charge, then it disappears...does your noise disappear after a while?
- my996duc1Explorer
Racorman wrote:
The power control converter that Attitude uses is pretty good unit (PD4000)
Give Progressive Dynamics a call or send them an email....
http://www.progressivedyn.com/contactus.html
THANK YOU !!!
I called and the lady knew exactly what I was talking about. She stated they are aware of the problem and are trying to figure it out. She took my name and number and said they will call owners having these issues once the problem is resolved. Very nice on the phone.
She said it will not hurt anything to let is buzz. If the low sound is annoying just turn on a small night light and that will stop it. Any 12v draw stops the noise.
Thanks again !
_
About Fifth Wheel Group
19,031 PostsLatest Activity: Apr 14, 2024
