- honda4usExplorer
jesse.m.jm wrote:
Thanks Honda. Did the AC come with the heat strip, or did you install that?
Came with the unit. We do use the ceramic heater more for the ease of it though. The garage floor is not insulated. It will be next season :) Y-Guy wrote:
Whitehouse did you keep the pics of your ducting project? I recall when you did that.
The other issue is that I'm not sure there is/was much insulation on some of the older Raptors in the garage walls and floors. The only time our garage was to cold to use was when we camped in the snow, the other times the ceramic heater kept it just fine.
No I wish I would have. But bkirkpatrick did. :) My 2009 Raptor is cooler than my 2006. Think it must be because of all the large windows.
As Y-Guy mentioned a small heater will keep it plenty warm.- Y-GuyModeratorWhitehouse did you keep the pics of your ducting project? I recall when you did that.
The other issue is that I'm not sure there is/was much insulation on some of the older Raptors in the garage walls and floors. The only time our garage was to cold to use was when we camped in the snow, the other times the ceramic heater kept it just fine. - I think many of the new ones do offer ducted heat to the garage. If not, you can modify it pretty easy. I ducted it on my 2006 3612 & my current one the previous owner ducted it.
- jesse_m_jmExplorerThat makes sense, thanks Y-Guy. We are looking at a Raptor to live in, and with the kids sleeping in the garage, want to make sure they don't turn into ice-cicles...
- Y-GuyModeratorMany garages do not offer heat or ducted air, our 3612 didn't. I think this is done to keep any garage fumes out of the main cabin. A separate AC unit that isn' ducted wouldn't have this problem. What we found was placing a small ceramic heater on the low/med setting kept the back plenty warm. Heat strips, in most cases, cost more then a ceramic heater and put out less heat.
- jesse_m_jmExplorerThanks Honda. Did the AC come with the heat strip, or did you install that?
- honda4usExplorerOur Raptor 381 has heat via the heat strip in the A/C No heat ducts.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
