JRMunn
Jul 09, 2017Explorer
Dometic AC Performance
For background, I am using my father's 2004 Sunnybrook Titan 28RLKS (three pop-outs) 5th wheel trailer after replacing tires and batteries. It was purchased used in about 2009 or 2010 with little use since then because of family health problems, and it shows very little wear inside. There is a single Dometic air conditioner that I assume is the standard option 13,500 BTU unit. I am running it with a Yamaha 3000esi generator, and I can hear (and feel) the compressor working. Air coming out of the roof vents is cool, but not cold, and the AC does not pull temperature from high 80's to high 70's within about an hour. Is this normal? Is there some typical maintenance needed on these AC units? Or does it need to be replaced?
In case it matters, there is an electronic thermostat that has options for AC, heater, and fan which allows setting the start-up temperature but does not show interior temperature. I know the heater works (after filling LP gas tanks), and I am running the AC with fan on AUTO. Much air comes out of the central AC vent, and much smaller amounts of air come out of smaller, circular ceiling vents. The thermostat has a ZONE setting button, but it does not seem to have any effect, so I assume that this is a single zone AC system.
Any suggestions or advice about improving the performance of this AC unit would be greatly appreciated. A big fan helps, but only after we are already hot.
