Dukecity426
Jul 17, 2021Explorer
time2roll wrote:
So the upper unit control box fixed the issue? You need a new control box. Or did I read that wrong?
If you want to go with a Honeywell or other home thermostat you would need to buy an old analog control box and probably pull new wire to the thermostat.
Yes that would be correct. The A/C worked just fine with the controller from the living area, and I installed it in the bedroom A/C and it worked just fine. So that is my way of diagnosing the problem. Thanks for your answer.
About Fifth Wheel Group
