Dukecity426
Jul 17, 2021Explorer
sayoung wrote:
If those are the " communicating " thermostats Dometic uses then your stuck . It can be done with some relays/wireing if you thought worth the trouble.
Yes, so far this seems to be what I have found out also. I will have to just find a way to live with this. I did however sort of fixed the problem, well maybe not a fix other than a way to keep the A/C running, not efficient though. I just set the temp to 66 degrees and it will run until turn off the A/C. Wasting energy. All though we need to maintain climate control in the RV for our pets.
Thanks again for your response........
About Fifth Wheel Group
