Fulltimers
Feb 25, 2019Explorer
New units can be very expensive unless you are thinking about a residential unit. As stated earlier if there is/was no ammonia smell and there is no yellow powdery residue around the gas burner (indicates a cooling unit leak) than a repair will be A LOT less expensive and less invasive than a replacement. Even if there is an ammonia smell or yellow residue it will still be a lot less expensive to repair.
If the cooling unit is ok then there isn’t much else left.
Control board, Blown fuse, Rodents ate wires, all fairly inexpensive.
About Fifth Wheel Group
19,042 PostsLatest Activity: Apr 15, 2026
