Old-Biscuit
Feb 25, 2019Explorer III
OK ....
So the 120V AC is NOT working
Have to start at outlet fridge power cord is plugged into
Does it work? (plug ANY 120V AC item into it and verify it is hot)
If NO..check for tripped 120V AC Circuit Breaker
IF YES
Then need to check the AC Fuse on the lower circuit board
Glass Fuse....5a most likely
Is fuse Good....120V AC on Both sides of fuse?
If NO...replace fuse and replace heat element
If YES...then need to check that you have AC Voltage on circuit board where the Electric Heat Element leads connect.
Typically when no cooling on AC
It is bad heat element
IF YES
About Fifth Wheel Group
19,042 PostsLatest Activity: Apr 15, 2026
