Old-Biscuit
Jun 29, 2013Explorer III
You model of fridge does not have a 'temp control' adjustment....pre-set at factory.
Freezing of stuff in fridge section is caused by three things
*Operation
'Manual' mode vs 'auto' mode. In manual fridge will cool continuously
Switch to 'auto' mode operation
*Thermistor
Faulty thermistor will cause continuous cooling
Thermistor fallen down...not held in clip..causes continuous cooling
Moving thermistor downward will make fridge section LESS cool (you can move clip from right fin to next fin but overall effect is only 6-8*F)
*Bad lower circuit board.....have board bench tested
IF thermistor is faulty you can replace just the tip with this kit
Repair kit link
*Operation
*Thermistor
Repair kit link
About Fifth Wheel Group
19,006 PostsLatest Activity: Feb 18, 2025
