peaeye1ExplorerJul 29, 2016Dometic thermostat malfunction.This is on a Winnebago 5th wheel.This thermostat can be set to one, two or both ac's.Both units work fine,fan,compressor, but the inside temp setting on the thermostat for the 2nd ac is now starting t...Show More
bgumExplorerJul 30, 2016clean contacts. You are experiencing communication problems between the boards in the AC and thermostat.
Related ContentDometic digital thermostatMalfunctioning Coleman ThermostatDitching Dometic Thermostat?Dometic Thermostat modDometic fridge WITHOUT thermostat
