bgum
Jul 31, 2016Explorer
There are two one inside one outside. The most likely one to be corroded is the outside. On mine it was the connector on the communication wire inside. There was a little bit green corrosion on both the wire end and the connector end. I cleaned both and after a couple resets of thermostat problem was solved. It doesn't take much to cause a problem.
About Fifth Wheel Group
