Jenobandito
Feb 24, 2017Explorer
Door height
Seven years I had a building built 14" tall so I could get a larger RV at some point. I knew nothing about doors, floors and sidewalls, but I told the large building company what I wanted. Bottom line...
Jenobandito wrote:
Seven years I had a building built 14" tall so I could get a larger RV at some point. I knew nothing about doors, floors and sidewalls, but I told the large building company what I wanted. Bottom line it could have been built so I could have a larger door, but since they did not listen to what I was going to do, I ended up with a low-profile door only 11'10 inches due to the position and tap of trusses. There is no room to change the door to another side.
Now that I am looking into a small 5th wheel with slides, I am not finding anything that will fit under my door, so without major changes will it be necessary to go with a trailer?
I can fit a 28' trailer into my building, but am looking into adding 10' on to the back. Length is not so much the issue now as getting something hopefully that would fit into the 28' with two full slides.
It is so time consuming looking at trailers, I though I could get some advice from all of you who can give me some advice.
