laknox
Mar 22, 2017Nomad
Cummins12V98 wrote:laknox wrote:MFL wrote:
No luck needed! With your experience, and well maintained rigs, you'll be a safe tow, even at 36K. Must be getting close to 75'. Post a pic, when your all hooked up in April.
Jerry
Yes, please double-check your length. For years I though AZ was 75' OAL, but when I checked ARS a couple years ago, I found that it was only 65', though I believe "overhang" from the rear trailer axle can be as much as 10', for 75'. I think this is where I got the 75' number from.
Lyle
For fun I will measure my overall length and will post a pic. I am guessing around 66' +.
Jerry thanks for the kind words!
I just did a quick-check on this, and 65' seems to be pretty hard and fast, but without reading the entire ARS under transportation, I can't confirm the "overhang" part. I was pretty sure that the OAL was nose to rear axle, with an allowable overhang "not to exceed X'", but I can't find it. If you're close to 65', I doubt you'll have a problem here, unless you run into the occasional a-hole LEO/MVD that cares more about the rules than common sense.
Lyle
About Fifth Wheel Group
