JIMNLIN
Jul 16, 2019Explorer III
TT and 5th wheels
Check out these folks who have been around the RV industry for around 60 years. Bought 2 truck campers from them in the '70s.
They have several 5th wheels and TT that the proper F150 can handle.
Not all F150 are the same.
F15o has 19 different GVWRs from 6000 on up to 8200 lbs and has 5 different RAWR from 3300 up to 4800 lbs.
To tow a 5th wheel trailer you will need the heavier duty 8200-7850 gvwr with a 4800 RAWR with 2500 lb payloads.
Or if its light enough the 7550 GVWR with the smaller 4550 RAWR will work with around 1800-2000 lb payloads.
There are lighter duty F150's like the 6800-7050 GVWR and real small 3800-4050 RAWR work better for 6k-7k TT's. These can have 1500-1800 lb payloads.
The 3.5 Ecoboost V6 twin turbo charged engine and the 5.0 v8 won't have any issue towing within their ratings.
F150 "MAX TOW" warning.
Ford markets this package as a option. Yes its a good option for towing duties. Many new F150 owners bit into the MAX TOW option with the lighter duty 6800 GVWR and 3800 RAWR thinking it could tow the max.
MAX TOW Includes:
• 3.55 Electronic-locking rear-axle
• 4-pin/7-pin wiring harness
• 36 Gallon fuel tank
• Auxiliary transmission oil cooler
• Engine oil cooler
• Class IV trailer hitch receiver
• Pro Trailer Backup Assist with Tailgate LED
• Smart Trailer Tow Connector (standard on LARIAT and higher)
• Integrated Trailer Brake Controller
• Upgraded front stabilizer bar
• Upgraded rear bumper
MAX TOW Includes:
• Engine oil cooler
About Fifth Wheel Group
