Hello Folks, We recently made a run from DFW to Temple, TX (2-3 hrs) in 90 degree heat. We ran the generator and the main AC along the way so the rig wasn't steaming hot when we arrived. When I opene...
Obviously the evap coil drip pan drain holes work cause condensation ran down/off roof when you had 5vr parked/set up. So sounds like with the high humidity more condensation developed and was carried over/leaked over out of drip pan bouncing down the road.
