Cummins12V98
Jul 11, 2015Explorer III
MNRon wrote:
korbe I'm with you, I don't understand the value of a pull test IF you visually see the jaws wrapped around the pin AND the wider pin flange below the jaws. I even painted my pin flange to make it easier to see this. I try to follow the proper process/procedure hooking up and ALWAYS visually look, but have never done a pull-test to double-check my visual check...just sayin', not recommending to others or trying to start a flame war...
Nice to see some people live by common sense!
With my B&W the kingpin plate and hitch plate are touching the handle is closed and LOCKED and the 1" thick jaws are closed around the kingpin it is hitched and can not separate.
About Fifth Wheel Group
