MarkTwain
Jul 11, 2015Explorer
MNRon wrote:
korbe I'm with you, I don't understand the value of a pull test IF you visually see the jaws wrapped around the pin AND the wider pin flange below the jaws. I even painted my pin flange to make it easier to see this. I try to follow the proper process/procedure hooking up and ALWAYS visually look, but have never done a pull-test to double-check my visual check...just sayin', not recommending to others or trying to start a flame war...
Micki Bitsko says "If you do the pull test you have nothing to loose and everything to gain". Every RV technician/sales that I have talked to has always recommended doing the pull test.
About Fifth Wheel Group
