Cummins12V98
Jul 11, 2015Explorer III
djgarcia wrote:MNRon wrote:
korbe I'm with you, I don't understand the value of a pull test IF you visually see the jaws wrapped around the pin AND the wider pin flange below the jaws. I even painted my pin flange to make it easier to see this. I try to follow the proper process/procedure hooking up and ALWAYS visually look, but have never done a pull-test to double-check my visual check...just sayin', not recommending to others or trying to start a flame war...
Micki Bitsko says "If you do the pull test you have nothing to loose and everything to gain". Every RV technician/sales that I have talked to has always recommended doing the pull test.
Do you really think they would tell you not to and risk a law suit?
When I had a RBW hitch I did a pull test. Made sense because you physically could not tell for a fact everything was latched.
If I had a hitch that had a color code or some other obscure method of latching I sure would do a pull test also!
Close the handle lock it and check that the plates are touching and the 1" jaws are closed. No need to do a pull test. Do a pull if you want but I do a visual test.
About Fifth Wheel Group
