Cummins12V98
Jul 12, 2015Explorer III
MFL wrote:Cummins12V98 wrote:djgarcia wrote:MNRon wrote:
korbe I'm with you, I don't understand the value of a pull test IF you visually see the jaws wrapped around the pin AND the wider pin flange below the jaws. I even painted my pin flange to make it easier to see this. I try to follow the proper process/procedure hooking up and ALWAYS visually look, but have never done a pull-test to double-check my visual check...just sayin', not recommending to others or trying to start a flame war...
Micki Bitsko says "If you do the pull test you have nothing to loose and everything to gain". Every RV technician/sales that I have talked to has always recommended doing the pull test.
Do you really think they would tell you not to and risk a law suit?
When I had a RBW hitch I did a pull test. Made sense because you physically could not tell for a fact everything was latched.
If I had a hitch that had a color code or some other obscure method of latching I sure would do a pull test also!
Close the handle lock it and check that the plates are touching and the 1" jaws are closed. No need to do a pull test. Do a pull if you want but I do a visual test.
When I purchased a similar hitch, to the one pictured, my first thought was, what keeps these jaws from opening.
I looked at the jaws, while working the lever, to see the workings inside. It was obvious, the way this hitch is designed, it cannot open with the lever closed, and locked/pinned.
You only need to see the jaws closed around the pin.
Jerry
Thank you!
One BIG reason I push B&W is because of their simple solid design. Newbies this is the hitch for you and people with the opportunity to change hitches really look them over. I went form a RBW that I "THOUGHT" was the best until a friend insisted I change to a B&W. What at first sold me was having a clean bed because I used my truck for construction. After using the hitch and doing a pull test fro a while I finally realized it was a waste of time. I from then on started doing a VISUAL test as you should with any hitch.
If you are happy with your hitch that's great or if you do a pull test that is great. I am giving my opinion and experience that others with a open mind can decide what's best for them.
In the market just don't go by what your dealer wants you to buy because that's what he makes the most money on do your research.
About Fifth Wheel Group
